13-07-2012, 08:59 AM
I have a 2001/Y 1.9 Diesel with front wipers that sometimes get into a state when they wont switch off, even with the ignition off. Sometimes a bit of wiggling with the wiper stalk does stop them but they have got so bad that I had to disconnect the battery to stop them. They appear to be stuck on the 'slow' setting. Even disconnecting the switch does not stop them.
After reading around the internet a bit there seemed a possibility that it was due to issues with the park contact in the wiper motor so I got a 2nd hand replacement motor and this seemed to fix things for a while but they have started doing the same thing again, though I am still able to stop them with a bit of stalk wiggling.
The garage have advised that if a new motor didn't fix it then it is probably the BSI. In this model this is below fuse box under steering wheel. They are also saying that it is no good getting a second hand one as this unit includes the coding for the key/imoboliser and they cannot be recoded.
I have read about a BSI reset procedure but the one that everyone links to on the BBA Reman site includes holding down the lock button on the key for 10 seconds and I have no central locking so I guess this for a different model.
Questions:
- Does anyone agree/disagree with the diagnosis that it is the BSI?
- Is there a way of replacing the BSI using a second hand unit and getting it recoded, without buying a new (£260) one?
- Has anyone used BBA Reman to get a unit like this repaired?
Thanks for any help,
Dan
Questions:
Dan
unny:
R4
