  • 7 Vote(s) - 2 Average
no instrument lights
Hi all
I have a 00 1.9 diesel berlingo with no instrument lights period. Went to start van after work and woomph nothing. Checked fuses and battery can anybody help.
seamus121
(16-07-2012, 11:05 AM)seamus121 Wrote:  Hi all
seamus121
Does the engine turn over?
Do your h/lights/interior lights come on ?
Do you mean no oil light/engine lights or no panel illumination lights ?
Did you check both fuse boxes ?
Confusedcratch:
seamus121
Engine does not turn over
head lights will come on
no oil light/engine/heater pug or panel lights
also checked all fuses
Confusedcratch:
Hi
Checked all fuses
i have headlights
van will not turn over
no oil light/engine heater plug or panel lights
seamus121
Confusedcratch:
Hi
Checked all fuses
i have headlights
Do your h/lights dim when trying to start it?
There are two earth cables from the neg. side of the battery. One bolts onto the gearbox (engine earth) and the other bolts onto the body, just under the battery (for body/lights etc.earth). If they are OK , look at the feed from pos. terminal to engine fusebox and the 40amp fuses in there . Does the starter solenoid click when trying to start ? It helps if you have a multimeter with long leads so as you try it you can watch for a voltage showing. (I'm assuming you know how to work a meter) If not get a mate to try to start it and you listen. The ignition switch is fed from the engine fuse box and if no clicks/voltage check those big fuses/earth cables
Theres an engine running relay that can play up sometimes caused by bad earth. its mounted under or near the battery,
There are also earth points in the cab on the L/h A pillar, hidden behind the plastic trim, these earth the instrument panel.
[-] The following 2 users say Thank You to brodfather11 for this post:
  • northants_guy, taxi
Been mulling it over , the common factor is the ignition switch
That could be your problem , try wiggling the key when starting it
If faulty/ or no power, you would'nt get ignition lights etc., and the starter wont work.
:thumbsup:
On a seperate note brodfather11 thanks for confirming the earth locations as I need to check these for a rogue eml issue I have.
(16-07-2012, 11:04 PM)brodfather11 Wrote:  Been mulling it over , the common factor is the ignition switch
:thumbsup:
Tried wiggling the key, no ignition lights but there is power coming up into the fuse box and up to the ignition tumbler
seamus121
Confusedcratch:
Hi
Checked all fuses
i have headlights
Hi earth cables are all solid/40 amp fuses also good there is power going to the starter but still no ignition to engage it. I will check out engine relay under or near the battery. Are they two small relays mounted together ? Thanks for all the help i really need to get back on the road can't afford a mechanic to look at it for me
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
