  • 9 Vote(s) - 3.44 Average
Berlingo M-S Desire 92 won't start...
[/size][/font]My Berlingo M-S Desire 92 won't start. When I switch on all the usual lights show up on the dashboard, but when I turn the key for the engine start there is a quiet click and nothing more. Very frustrating, help please. Valerie Green
(16-07-2012, 05:36 PM)Valerie Green Wrote:  [/size][/font]My Berlingo M-S Desire 92 won't start. When I switch on all the usual lights show up on the dashboard, but when I turn the key for the engine start there is a quiet click and nothing more. Very frustrating, help please. Valerie Green
I'm a little rusty on general car mechanics Valerie due to aching joints & time etc but....
Dash-lights on & just a click on turning the key:- low battery perhaps, enough to light up dashboard but not enough to turn starter motor. Starter solenoid stuck - this could be rectified by putting car in 3rd gear & rocking back and forth to release bendix drive. May require a friend to help rocking the car -push forward & pull back as quickly as you can!
I'm sure that there are better qualified folk on this site who could offer better advice as I am a little out of touch, but that does sound like a familiar problem with any car.
Hope you get it sorted out soon.
Good luck, Adrian/Citroaddict/newtoberlingo. Wink
03 2.0HDI Forte. I need more cash....
Put your headlights on and then try to start it. If the headlights dim you need a new battery, if not as Citroadict says try rocking it in gear.
Oh and by the way - hello, nice of you to drop in.........
  • CitroAddict
As Coco says, try starting and see if headlights dim significantly etc....
Don't forget to say hello on the site here, they are a good bunch as I have learned in a short time, much help once you get used to finding it.
Unfortunately rocking in gear only works on stone age starters(inertia type).
Modern pre-engaged starters have a one way clutch which would be damaged if it was stuck in mesh & rocked.
Check engine/battery earth connections & battery condition.
  • CitroAddict
Good point Ron & as I said I am a little out of touch with car mechanics. I read the post as being a '92 vehicle so would stone age starter principles apply?
Thanks, I have learned something new tonight. Confusedalut:
Thank you everyone, I will check the 'headlight dimming' first and take it from there. Grateful for the kindly words and prompt attention. Valerie
(16-07-2012, 07:55 PM)CitroAddict Wrote:  Good point Ron & as I said I am a little out of touch with car mechanics. I read the post as being a '92 vehicle so would stone age starter principles apply?
Hi CitroAddict...In this case 92 refers to 92bhp which probably means that the car is a 1.6TDi.
HTH
  • CitroAddict
Aye sir O'l J, oops on my behalf! Confusedillyme:
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
