  • 9 Vote(s) - 3.44 Average
my fixes
while under the bonnet i noticed the hex bolt (circled and labeled A) was loose
figured i must be losing boost pressure so tryed to tighten it but no joy
popped off the other bolt and pulled it all apart and discovered the green o ring was missing a section (labeled b) and that seals part C
so i resealed it all with locktight seal
and put a screw in the air duct to the air filter to stop it coming apart
hopefully it help proformance and mpg abit hard to tell on a short trip with a cold engine but there has to be a disadvantage to a leaking turbo
Attached Files Thumbnail(s)
as we say here that looks a "proper job" could you hear the turbo leaking before? probably not with all the sound proofing under the bonnet it should be better now you have sealed it .I was considering fitting a boost gauge to mine I guess that would show any problems as they develop .I must admit my air filter / pipes are rattling around on top of the engine there seem to be some rubber bits that attach it to the top of the engine missing all seems a bit plastic and flimsy.
Jamie
ta everything seems held with rubber bushes.
well you could see the oil on the engine so it must have been blowing, presume the oil is from the egr valve,
Yesterday 07:31 AM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
OIL Drip
Last Post: Martinze
10-03-2026 06:08 PM
10-03-2026 02:49 PM
New owner in Bristol UK
Last Post: JPCoetzee
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
