Thanks Received: 2 in 2 posts
Thanks Given: 2
I replaced my fuel filter on my berlingo 1.9d non turbo, the van will now not start, When i first started it it run for a few second then cut out, i tried priming it and it still wont start, Am i doing something wrong???
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Make sure all the connections are sound, including the fuel heater (very tight to fit, someone suggested a hammer!).
Then pump like mad on the primer. Mine took quite a bit of squeezing. :whistle:
The following 1 user says Thank You to j90xxx for this post:1 user says Thank You to j90xxx for this post
• sharpy
Threads: 101
Thanks Given: 384
Well done.:woop:
Thought that might cure it.
Mine took a while.
