  • 12 Vote(s) - 3 Average
Does my van have a DPF / FAP
Downstream of the turbo behind the radiator it has an enormous drum thing, much bigger than any cat I have seen - it looks like a DPF. It is quite hidden under a heat shield, however I can not see any pressure or temperature sensors either above or below it that I would associate with a DPF.
There seems to be no lights on the dash that would warn of regeneration, and I cannot find the reservoir for the additive (not entirely sure where to look)
its an 09 plate mk2 van
Any thoughts
The probable answer is 'Yes'.
I believe that all of the 1.6 Diesel turbo vehicles were fitted with a DPF (FAP)
from late 2006. My early 2006 1.6 was one of the last, apparently, not to have that
piece of junk fitted as standard.
Yes.:thumbsup:
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
