24-07-2012, 05:53 PM
Hi Folks,
2002 Berlingo Multispace 1.4 petrol WITH aircon.
Several times we have had a problem with overheating. In 2010 a garage replaced the temp sender, but I'm not convinced it's the correct one. It's blue with 3 pins but there are only 2 green wires connected to the connecting plug.
I replaced the thermostat last Nov, which seemed to cure it, but now with the hot weather it's started overheating again when in slow traffic.
I've looked at replacement senders on the internet and all seem to only have 2 pins.
Can someone please confirm part number for;
1. Correct sender unit
2. Correct connecting plug
3. Wiring diagram (Haynes manual confusing)
I suspect the problem is the fans aren't comming on but as it's always the wife driving solo I'm not there to confirm this. Also what difference does it make having aircon as to which sender is fitted?
Many thanks,
Griff :wave:
Many thanks,
Griff :wave:
Landmark
Ex 1.4 Berlingo Multispace
alut:
