Hi
We are about to pick up a 2003 berlingo multispace. Just one thing we're worrying about - our local council has installed a barrier at the tip with a height limit of 6ft. As far as I can see from online specifications, that only leaves about 1cm clearance. Are we safe to use it?
Threads: 51
Thanks Given: 23
Eat more pies!
I make mine (with part worn tyres) about 2cm under 6ft. I'd complain if I were you. A limit of 6ft would make quite a few cars eg. people carriers, hit the barrier.
Malc
Stupid computer!
Threads: 30
Thanks Received: 55 in 42 posts
Thanks Given: 104
Hi there - if you have a look around on this forum I think there's a manual online that gives the dimensions. Or maybe do a Google. The radio aerial will probably give a loud 'dong' when you drive through - just go carefully if you're reversing out as the aerial will catch.
Hope you enjoy your new car!
Threads: 11
Thanks Received: 17 in 14 posts
Thanks Given: 79
25-07-2012, 05:42 AM
(This post was last modified: 25-07-2012, 06:03 AM by CitroAddict.)
"Height limit of 6ft?" I would have thought that you may find your vehicle dimensions in the Citroen handbook if there is one with the vehicle. To be pedantic, it may be worth going to your tip with a tape measure when nobody is looking and measure the height of the barrier. If it is inaccurate and you then come a cropper you may be able to claim against the council. Cynical? Maybe...
You could always measure the height of your vehicle at its highest point using a tape measure, straight edge & spirit level.
6 foot seems rather low, there are people taller than that but not so many in Wales. If it all goes tits up don't forget to send in pictures.
One thing confuses me however.... you are about to pick up your new Berlingo and take it to the tip ??? Must have more money than sense!
illyme:
03 2.0HDI Forte. I need more cash....
Threads: 63
Thanks Given: 410
You may well find that the local tip a.k.a. Civic Amenity Site is not operated by the council anymore and is operated by a contractor so if you do need to claim anytime then you need to determine who to claim against.
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
My local tip has a barrier when you go in to and I let my partner drive in whilst I stand on tow bar lol, otherwise my roof bars would catch and whilst putting weight on tow bar it gives a couple of centimetres clearance.
On the other hand my father in law has a Peugeot partner escapade with a full roof rack on and when he goes under it scrapes all way along but he not bothered, I do know the escapade is a little higher than berlingo though
Threads: 20
Thanks Received: 60 in 52 posts
Thanks Given: 19
They should lift the barriers though I'd have thought, my local tip used to for me when I had the Rangie that was about 8ft tall lol.
Sent from my BlackBerry 9800 using Tapatalk
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free
