Hi guys
I wanted to share you guys with a little mod I am working on.
It seemed to me like a good idea to install a USB charging port next to the rear view mirror.
A USB charging port in this location could use to power all kind of front windshield mounted equipment like GPS video camera etc with having the advantage of using a shorter than normal USB cable.
It happens to be that in my MK2 berlingo I have a rectangle plastic piece next to the upper mirror that can be used for that purposes.
BOM:
Panel mount USB socket from eBay
7805 analogue +5Volt voltage regulator from ebay
DC socket from ebay (optional)
Small heat sink, Wires and Heat shrink
7805 wiring
[Image: 5_VDC.jpg]
Attached below is picture of the finished product.
Heat sink is connected to the regulator using a heat conductive glue, other heat sink can use a nut + bolt
I also added a DC socket for direct 12VDC connection.
Later today once installed I will upload more pictures with the final look in my berlingo.
Thx
Samuel.
[Image: 20120727_104231.jpg]
[Image: 20120727_103812.jpg]
[Image: 20120727_112603.jpg]
Final result:
[Image: 20120727_193447.jpg]
My little helper holding a super buddy speaker kit
[Image: 20120727_193757.jpg]
BOM:
7805 wiring
[Image: 5_VDC.jpg]
Thx
Samuel.
Final result:
alut:
