  • 10 Vote(s) - 2.4 Average
Strange device on fuel line
Does anyone know what this is for, I am not sure if it is the feed or return on a 1.6hdi. Its got me puzzled.
May be its to make the diesel go further, about 80 inches further
[Image: in8jmx.jpg]
How odd, I've never seen one of those before. My guess is that it's for cooling the fuel. And if so it may well be on the return side as I presume pressurising the fuel will heat it.
Malc
Stupid computer!
It is a cooler. Have a look here. It is part no. 10.
(27-07-2012, 12:02 PM)crickleymal Wrote:  How odd, I've never seen one of those before. My guess is that it's for cooling the fuel. And if so it may well be on the return side as I presume pressurising the fuel will heat it.
Yes, my thoughts were it looked like something off a fridge, presumably the fuel must be spending enough time at the engine to become warm, I wonder if all common rail diesels have them. I have never seen one before.
I was actually looking to see if I could find the dpf fuel additive reservoir. It's certainly well hidden, tucked up behind the fuel filler pipe, I guess the plastic inner wheel arch must be removed to access it / fill it up.
And here (i think) is the additive tank, situated just in front of the drivers side rear wheel arch and below the filler cap. I believe the additive tank is what the corrugated style pipe leads to, I guess the green wire goes to the sensor level.
[Image: 24ymxzs.jpg]
Fuel cooling plate, as its name suggests to cool the fuel. Most commonly found on large trucks and heavy goods type vehicles...
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
