  • 9 Vote(s) - 2.89 Average
16" 406 steel wheels
Have acquired a set of these and tried them on the van, not really over keen on them so probably going to sell them.
Set of 4 16" 406 coupe steels, with tyres (not great)
Will take £160 for the set, one of my pals might be after them as well so might end up taking them down....
Chris
Sold to coco!
Sorry for the necropost/bump, but do these size rims clear the facelift 607 brakes (330mm, TRW caliper)? I'm window-shopping for calipers on Leboncoin, and when I crunched the net diameter, it comes rather close...
Cheers, Adam.
Can't help on that one.
They go on the Partner fine, but brakes are standard
Ta. One of the Belgian fellows has told me you must run 17s as a minimum with the 330mm discs.
Looks like the biggest readily fitted brakes are the four pot Brembo calipers and 305mm rotors off a 406 Coupé. Not sure if this requires a hub change and new driveshaft stubs to add 10mm offset per side, but probably.
The Brembos and discs go straight on a 306 so I see no reason why they shouldn't go straight onto a Berlingo.
Last Post: allanr
Today 06:16 PM
Last Post: allanr
Today 05:57 PM
Oil consumption at 200K miles
Last Post: Buki
Today 08:29 AM
Forum activity
Yesterday 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
