  • 6 Vote(s) - 4.33 Average
Live 12 volt power supply
Is there a way of enabling the cigar lighter sockets to remain live once the ignition is switched off? There isn't an accessory setting on the ignition swiitch.
Thanks in advance.
Phil
(31-07-2012, 05:16 PM)Squadron Leader Wrote:  Is there a way of enabling the cigar lighter sockets to remain live once the ignition is switched off? There isn't an accessory setting on the ignition swiitch.
Thanks in advance.
Phil
i took a live direct from the battery to the cig lighter.what a pig of a job.Angry
I am not sure its a good idea having the lighter connected directly to the battery, i think that due to the amount of power the lighter needs its better to use it only when engine is working and the alternator (dynamo) is giving the power.
(31-07-2012, 07:03 PM)LoveMyCar Wrote:  I am not sure its a good idea having the lighter connected directly to the battery, i think that due to the amount of power the lighter needs its better to use it only when engine is working and the alternator (dynamo) is giving the power.
It depends largely on what item is plugged into the lighter socket
if you're using it for SatNav or phone re-charging it should be OK.
Personally, I would NEVER smoke in my car.
I don't smoke anyway :lol: The reason I asked was because I have a sat-nav that also has built-in freeview so for those times when you're waiting for your wife while she's shopping it would be nice to to watch a bit of tv, catch up on the news channel etc.
[quote='Squadron Leader' pid='24440' dateline='1343805304']
Did'nt know sat-nav could do that. What make model is it, might get one for myself. :drool:
P.S. You'll be doing a lot of freeview watching then ? :whistle:
Has your model got the modu-top roof?
If so the 12v sockets in there are always live, so you could plug into those?
(01-08-2012, 09:43 AM)brodfather11 Wrote:  [quote='Squadron Leader' pid='24440' dateline='1343805304']
It's one of the Garmin Nuvi range. It is a useful bit of kit and tv too.
Using it a lot? yes, that's women for you. Lol.
Sadly no it hasn't. Sad
(01-08-2012, 09:55 AM)tucker Wrote:  Has your model got the modu-top roof?
its only for the sat-nav.i was sick of it turning off every time i switched off.i fitted an in-line fuse anyway
my modutop doesnt have a cig lighter!!! 04 desire
I think the reference is to the two power sockets in the rear seats overhead lockers
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
