Threads: 16
Thanks Received: 10 in 9 posts
Thanks Given: 2
Evening All!
Been offered a roof rack for my Bertie (Berlingo) but not sure it has all the bolts. It has the brackets but unsure if all bolts are there...
What bolts does it need, as I don't want to turn up and then not be able to attach it to Bertie to bring home. Or worse have to strap it to the existing rubbish roof bars I have.
Any ideas or pictures. :-)
Thanks in advance!
Threads: 63
Thanks Given: 410
As roof racks come in a variety of designs and by various manufacturers then it is impossible to generalise on what sizes will be required and with respect we are not mind readers on here......
Threads: 9
Thanks Received: 31 in 26 posts
Thanks Given: 8
If it is the sort that bolts through the roof do not touch it with a barge pole (IMO).
Roof racks should attach WITHOUT BOLTS to the six tabs on the roof i.e. they should hook into the tabs.
If any bolts are involved they will be the ones that hold the roof rack itself together.
The sort which bolt through the roof are I suppose more secure against removal but that's about all the benefit I can see, and against is irreversible damage to the vehicle and risk of leaks through every bolt hole.
Threads: 6
Thanks Given: 2
How rubbish are your existing roof bars? I could do with a set.
Ian
Mk1 Berlingo
