  • 10 Vote(s) - 2.7 Average
niggles
hiya lads , im am pleased with my berlingo ,but it has a few thngs that need ironing out
when i turn on ignition 4550 comes up,is this a fault code?
also when going downhill and then brake qickly the STOP and handbrake lights come on [with buzzer] for a couple of seconds
oil and brake fluid are fine
power steering fluid is just above the min
cheers boys,steve
03 1.9DLX van
I had the STOP light on. My brake fluid was within the min to max. I topped it up to max and now it doesn't happen anymore. Is your brake fluid filled to the max?
Lliam
Lliam
70 plate Berlingo
[-] The following 1 user says Thank You to lemsworld for this post:
  • stevetiler
(24-02-2011, 02:24 PM)lemsworld Wrote:  I had the STOP light on. My brake fluid was within the min to max. I topped it up to max and now it doesn't happen anymore. Is your brake fluid filled to the max?
Lliam
very small reservoir and very shallow too.
.ill try that lads,cheers
03 1.9DLX van
[/quote]
(24-02-2011, 05:11 PM)corkgsxr Wrote:  very small reservoir and very shallow too.
If you've seen any of the spaghetti westerns starring Clint Eastwood and Lee Van Cleef, you sound a bit like Lee Van Cleef, "Small world and very very bad"
(24-02-2011, 11:11 AM)stevetiler Wrote:  when i turn on ignition 4550 comes up,is this a fault code?
Does it have a spanner next to it? It's the number of miles until service is required.
Yes sounds like miles to next service to me
it does have spanner ,nice one boys
good forum this,steve
03 1.9DLX van
thanks liam ,topped up brake and power steering fluid ,SSSSOOOOOOOOOORRTED!!!!
03 1.9DLX van
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
17-10-2026 05:41 PM
