05-08-2012, 10:58 AM
(This post was last modified: 05-08-2012, 11:09 AM by Gus_in_Spain.)
Hi, I have a 1997 diesel Berlingo Combi, according to vehicle papers the engine is D-D9B. Unfortunately due to running out of refrigeration liquid abruptly it has blown the head gasket. A mechanic has suggested replacing the current engine with a reconditioned one, or maybe from a breaker's.
I would be interested to know what choice of engines there is, maybe from Xantia or Peugeot Partner, if anyone has experience with this problem.
MTIA
Gus
Enviado desde P1000 con Tapatalk
Sent from P1000 via Tapatalk
MTIA
Gus
alut:
was the engine from a ZX, on the basis that it was newer, and had done much less hard labour. It should be pointed out that this engine comes with a Bosch injector rather than the shoddy one my van originally had, and thus makes for a vast improvement in fuel consumption and performance at low revs. The clutch from the ZX was also installed as there was a difference in plate size assembly.
