  • 5 Vote(s) - 3 Average
[Tires & Wheels] Fitting alloys?
Hi ive got a MK3 Berlingo Van and i was wondering if i could fit 17" Alloys on ok? The PCD is 108 which i think is ok and the Offset is 15,the width is 7.5j any help would be appreciated thanks in advance.
http://www.carlsalter.com/citroen-wheel-fitments.html
Pretty reliable source.
You can see and compare the actual specs at the hub.
I know from personal experience the MK3 is pretty much open to most variations,as opposed to the MK1/2.
But do stick to the same centre bore size though.
Obviously check out the "other badge" list for the suitable models.
Just leaves the diameter.
Even with 195/65 profile the 15" leaves loads of room so with a low profile the 17" should be fine.
This is another good site-
http://www.1010tires.com/tiresizecalculator.asp
You can then minimise the effect the change will have on your speedo/odometer.
And your warranty.
If youre going for wider spec then be careful to check clearance on full lock to lock and double check inside each of the four arches for different obstructions etc.
Dont forget locking wheelnuts and watch the potholes.
Inform/pay your insurance company of the mods (or have a set of suspiciously clean steels handy to pop on if the inevitable happens....:whistleSmile
(06-08-2012, 04:52 PM)evdama Wrote:  http://www.carlsalter.com/citroen-wheel-fitments.html
And your warranty.
Thanks very much for the info Evdama Smile
Yesterday 03:36 PM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
