06-08-2012, 04:20 PM
The UK MOT is set to be replaced with the EU Road Worthiness Tests.
Over and above the UK's MOT it will more stringently test emissions, noise, brake fluid and anti-theft devices. Re-testing rules will also change depending on the category of failure. The proposals also cover inspections of transmission and engines for 'illegal modifications'
So what?
These things are usually the icebergs tip - left unchecked you end up needing a certified technician just to change a light bulb for you(Mk2 headlamps already do..
Time to get behind a lobby organisation and push back methinks
I have BMF membership so I know Im doing my bit.
So what?
)Time to get behind a lobby organisation and push back methinks
