  • 10 Vote(s) - 3.5 Average
heater blower wiring
Just bought (4 weeks) a mk1 berlingo (early 2002) which has had the wiring butchered. Managed to sort it a bit and most things are now working correctly. But the blower doesn't switch off when the ignition is turned off, and I can't relate the Haynes diagram to the actual wiring. Anyone got access to the official wiring schematics?
The body number is VF7MFWJYB65879853.
Thanks in advance.
Married to BandanaLady.co.uk
Hi, Are these any use to you ? The 803 line is on the second attachment.
Confusedalut:
[-] The following 2 users say Thank You to Rustscrat for this post:
  • avocado, billskipton
(13-08-2012, 09:19 PM)Rustscrat Wrote:  Hi, Are these any use to you ? The 803 line is on the second attachment.
Confusedalut:
Thanks!
Obviously don't know how useful they will be until I get stuck in (and that won't be until the weekend) but they certainly look of more use than what Haynes has to offer. Thanks again - I'll let you know what happens.
Is this wiring the same for a 2007
(19-01-2013, 08:26 PM)Tiddgas Wrote:  Is this wiring the same for a 2007
Almost certainly not the same. You could however give Rustscrat our guru a shout with your RPO and PM him your VIN and you may be lucky! Good luck.
Wire through bulkhead
Last Post: Jakejjt
Today 05:25 PM
Loose tailgate spoiler
Today 04:52 PM
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
