  • 10 Vote(s) - 3.4 Average
Noisy sounds at higher rpm-s
Hello
I don't know what the problem is, so i recorded this sound (in the html attachment) which is heard near the belt. This sound was never heard before the summer but now after air conditioning is almost always on, sound become more and more noisy (and i am worried about it). Other things work normal (acceleration, engine, air conditioning ...)
Please help me what to do and what is the cause of this sound
https://rapidshare.com/files/3127250602/MVI_6083.mp3 (Save file to ... ... your computer - button download))
Attached Files Thumbnail(s)
(08-08-2012, 06:56 PM)abrezo Wrote:  Hello
Hello all. First post on here Big Grin
I have the same noise in a 2006 1.4 multispace. Any help would be greatly appreciated
Many thanks
Have you tried taking off the drive belt to isolate the noise?
If you slacken off the belt or remove it and turn alternator , a/c pump and if you have power steering pump, the pump and any belt tensioners and see if they rotate smoothly and easily.
Start the engine without the belt on , if OK the you know the noise is not the engine, just whatever is turned by the belt.
It will narrow down where the noise is coming from. The belt itself, if worn may cause the noise. (shwissing )
Alternator/steering pump/,a/c compresser/ tensioner bearings can and do wear.
Wink
Check the crank pulley.
it was a bearing in steering pump.
[-] The following 1 user says Thank You to abrezo for this post:
  • andy-womble
Abrezo
Thanks for letting us know
:thumbsup::thumbsup:Confusedalut:
Albrezo, glad you have solved your problem and always nice to report back so that other people benefit from your experiences. Thank you..
Thanks for all that info guys.
Turned out that we had a more serious problem in that the head gasket has gone.
Overheated on the way home on Monday night there and had it checked by a mechanic and he said the head gasket has gone.
It is possible that the noise and the gasket failure are unrelated I suppose... A real sickener though and typically it happens right at the start of our busiest work period.
The car is 2006 1.4. Bought new and has been well maintained and driven well.
Local Citroen dealer has quoted £522 inc VAT for the lot. Assuming the head hasn't cracked that is...
Cheers again for all the help
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
