  • 4 Vote(s) - 2 Average
No Brake lights
Hi all, id really apreciate any help and advice on this so thanks in advance.
Both brake lights are not working although the rear window brake light is.
Iv changed the bulbs and checked the brake pedal switch - both ok.
Checked contacts in rear cluster for power - all ok apart from brake lights.
Van is a 56 berlingo 1.9 diesel
Any ideas?
Thanks, Peter
Quote:Checked contacts in rear cluster for power - all ok apart from brake lights
From that I understand that the brake light sockets are without power. Did you check fuses?? Maybe the main brake lights are fused separately.
According to the haynes manual fuse no5 in the driver side fuse box is for the brake light switch.
The fuse looked ok but i changed it anyway - still no lights.
Hi, check fuse 20 & 21.
Although if your rear window light is working your N/S rear should be as this is on the same leg but with a different earth.
Check your earths to both clusters, they should be behind each of the light units. Look for corrosion around each connecter and bulb holder. Confusedalut:
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
