Threads: 67
Thanks Given: 237
50
. Ok so I need the radio code ...original radio... before I go disconnecting the battery to work on my vehicle...it works just fine right now.
My Berlingo van 1.9d 2005 came without any owners handbook and radio booklet / radio code.
1/ Is there any way I can extract the code from it using the radio display ?
2/ If not will Citroen have this information at their fingertips and be willing to give it to me for free if I present them with my ownership documents ? I seem to recall doing this a few years ago with a Vauxhall I had.
3/ If I end up having to pay money out of my wallet for this which is the most cost effective method and how much will it cost me ?
Regards to you all, Geoff.
Serieal Berlingo owner
Threads: 51
Thanks Given: 23
I'll be watching this to see if you find a solution because I'm in the same boat. Does the radio even have a code? Having a quick look at the owners book suggests that it doesn't.
I can email a pdf of the owners book if you like
Malc
Stupid computer!
Threads: 67
Thanks Given: 237
50
Hello Malc I already have the owners handbook which you were kind enough to email me a copy of, page 38 mentions the anti theft system as being vehicle specific so it seems a code is required, shame really.
Threads: 63
Thanks Given: 410
Think manufacturers O/E radios are coded by computer at dealers...
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Think Andy is right, taken mine out 3 or 4 times. Never needed a code when put back in.
The following 1 user says Thank You to j90xxx for this post:1 user says Thank You to j90xxx for this post
• geoff
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
12-08-2012, 06:50 PM
(This post was last modified: 12-08-2012, 06:54 PM by Rustscrat.)
Hi, if it's an original radio/cd, then it's coded with your vin number so disconnecting it is not a problem, it just won't work in anybody elses vehicle.
To be on the safe side though I would do a Bsi shutdown first as this unit is on a comms line to the display & bsi etc.:thumbsup:
2006 2.0hdi 600 with bench seat.
Threads: 20
Thanks Given: 2,126
18
I have one of those battery tools that you plug into a aux socket.I charge it up overnight before use & plug it in before disconnecting the battery.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• geoff
Threads: 67
Thanks Given: 237
50
That is excellent news, many thanks to you all for your help. This learning curve is going well and hopefully I will be able to return the favour before too long.
I like the idea of the battery tool in the auxiliary socket could come in useful in the future.
Threads: 2
Thanks Received: 14 in 11 posts
Thanks Given: 24
Radio code savers can be found on ebay for under 15 quid. How necessary are they I cant say. I have not had any problems when needing to disconnect the battery for shortish periods. I can feel the pull of wikipedia coming on.
Threads: 67
Thanks Given: 237
50
I have done the work now and can confirm that the battery disconnection doesn't affect the radio - there is no code needed at all.
Thanks all. Geoff.
• ron
