12-08-2012, 09:17 AM
I'm just starting to replace the timing belt on my 2005 1.9D and have a question : the engine has the fixed camshaft pulley like a 2 litre.
The Haynes manual advises that the crankshaft sprocket should be turned
" Fully anti-clockwise to the limit of the movement afforded by the keyway.
Lock the sprocket in this position by inserting a 2.0 mm diameter rod down the left-hand side of the woodruff key. "
I am fine with performing the above function but what concerns me is where the manual states " lock the sprocket " since when the 2.0 mm rod is inserted the sprocket most definitely isn't locked and still has free movement. In fact it takes a rod of around 3.5mm to lock the sprocket !
Can someone confirm that the size rod specified in the Haynes manual is correct ?
I've done many a timing belt over the years without issue so I'm not without ability - perhaps I am worrying over nothing but I'd rather be sure.
Geoff.
Geoff.
Serieal Berlingo owner
alut:
