Threads: 16
Thanks Received: 3 in 3 posts
Thanks Given: 2
Looking from above the engine I can see straight through to the ground below. Should my berlingo have an undertray or is this normal? It looks as if there are fixing points around where a tray would fit... Most of my other vehicles have trays.
Cheers,
Threads: 20
Thanks Given: 2,126
18
What year & model? I think some earlier models didn't have them.
Strawberry flavoured windows
Threads: 12
Thanks Received: 5 in 5 posts
Mine had an undertray, they are crap and fall off, good chance yours has done the same......
Threads: 81
Thanks Given: 165
20
09-09-2012, 02:47 PM
(This post was last modified: 09-09-2012, 02:48 PM by evdama.)
(08-09-2012, 08:37 PM)ron Wrote: (14-08-2012, 10:37 PM)markyr2k1 Wrote: Its 2007 1.6hdi van
Sorry for slow answer.Mine is a 57 HDi multispace & has a shield.
I had an 07 1.6hdi 75 6ooX van - it had one.
I wouldnt worry-and it will make maintenance /repair a tiny bit quicker without it.
You often see them flapping up and down with the driver either oblivious or a puzzled look on their face
Threads: 67
Thanks Given: 237
50
Is there a tangible benefit to the undertray ?
I suppose there must be as the manufacturers wouldn't fit them, anyone know the real reason ?
If it is for pass by noise for environmental reasons then I wouldn't fit one but if it has some sort of streamlining and fuel efficiency benefit then it may be worth having one.
Serieal Berlingo owner
Threads: 32
Thanks Given: 24
It is an assistance in passing noise regs. As for further design uses, in this case I don't know, but I did once read an article showing how on the 405 it aided cooling quite considerably.
The following 1 user says Thank You to Coco for this post:1 user says Thank You to Coco for this post
• geoff
