Threads: 11
Thanks Received: 4 in 3 posts
Does anyone know how to get rid of the airbag light, had a little crash airbag didnt go off but the light came on, can it be reset or do i have to take it to citroen?
Threads: 12
Thanks Received: 5 in 5 posts
Mine does this from time to time, I just give the small connector block at the front of the drivers seat a wiggle, turn the ignition off then on again and that sorts it....
Threads: 3
Have had the same problem, and tried the same thing and no light for the past few weeks so wort a try.
Thanks Received: 17 in 13 posts
Thanks Given: 10
And me, seems to be a common problem but easily sorted with a wiggle (so far)
Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
Wish mine was a wiggle to sort it. It turned out to be the flat coiled cable behind the steering wheel that had fractured. New comm unit needed
Threads: 11
It worked very strange just wiggled the wires and it went off cheers
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
My Clio used to be the same.
Common fault all round.
