  • 17 Vote(s) - 3.53 Average
Stereo Removal...
What do I need to remove my citroen stereo and put a new one in? My husband said something about a key???
If I need a special key, I don't have one, will one from another stereo work?
Been a while since i saw a Berlingo headunit but from memory there should be 4 holes on the front of the stereo. Citroen reccommend a key that looks like this:
[Image: blaupunktdetail.jpg]
But all i would do is find 4 long and thin nails, push them in and out it would pop.
I removed the standard radio/cassette from my Mk2 the other day and used something almost exactly like the "keys" in the picture above, I originally bought mine from Ebay to change the stereo in my wifes Ford Fiesta but the same keys worked on the Citroen stereo.
Although the keys only cost a few £'s they do make things very simple, simply push into the holes each side of the stereo, then pull them out with the stereo attached.
You could of course use a DIY solution using 4 long nails or similar, but it may be a little more awkward.
Please make sure you disconnect the vehicle battery before changing the stereo, otherwise you may inadvertantly blow the 20A Stereo fuse (located in the fusebox under the steering column).
As for other connections, it will depend on the stereo you are fitting. I found my Alpine stereo was a straight swap. Although you may find that the central display unit on top of the dash will no longer display radio station information, or the steering column stereo controls may no longer work unless you buy a patch lead suited to your stereo.
Yep, that sound right! On a scale of 1-10 (10 being hardest) how easy is it to swap a stereo? I've never done it before!
Many Thanks!
Not terribly difficult. The hardest bit is getting the new one to fit neatly in the hole. It obviously won't match as the Citroen one has a specifically shaped bit of plastic on the front. You may find the aerial socket is different - Halfords sell adaptors at "Ouch my wallet hurts" prices.The wiring is probably fairly standar, you can buy adaptors for that if necessary. You may find the control stalk on the steering column won't work.
(23-08-2012, 02:08 PM)hachiroku Wrote:  Please make sure you disconnect the vehicle battery before changing the stereo, otherwise you may inadvertantly blow the 20A Stereo fuse (located in the fusebox under the steering column).
Or take the fuse out?
Malc
Stupid computer!
Think mine looks ok in the Citroen 'hole'.
[Image: sea8oj.jpg]
[-] The following 1 user says Thank You to j90xxx for this post:
  • Merlecollins
(23-08-2012, 06:15 PM)crickleymal Wrote:  Or take the fuse out?
aha! now that I know where the fuse is that would definately be an easier optionBig Grin
(23-08-2012, 06:22 PM)j90xxx Wrote:  Think mine looks ok in the Citroen 'hole'.
[Image: sea8oj.jpg]
If mine looks as good as that then I'll be happy, I'll find out tomorrow.... :S
Wire coathangers are approximately the same gauge of wire to make the tool.........make the citroen shape shown, but bend the legs in toward each other a touch at the tips and you will find it works nicely!!
Chris
This is my stereo if it is a fairly new cd player your fitting it is straight forward as it should have the standard iso connections as others have said you will loose the function of the lcd display and also the steering wheel controls. One other thing is the wiring on your new stereo should have a red and yellow wire these need to be swapped over so that red goes to yellow and vice versa by doing this it will keep its memory functions.
If you get stuck pop back on here
[Image: 15dlyye.jpg]
These are the red and yellow wires and need to be swapped over red to yellow and yellow to red , hope this helps
[Image: auwmqc.jpg]
[-] The following 2 users say Thank You to BerlingoHDI for this post:
  • dampy78, UnicornAngie
[Image: sea8oj.jpg]
That looks fine to me "suits you sir"
SOLVED: P20F6 fault
Today 08:28 AM
Coolant
Last Post: Martinze
Yesterday 08:24 PM
Leaking windscreen or aerial
15-04-2026 08:50 PM
