  • 13 Vote(s) - 3.08 Average
Key pad reset or disarm
Hi all, I am still having problems after the main stealers told me that the plugs needed replacing and then it was an oil pressure sensor to get my 97 1.9 going again.
I have just realised that the immobilizer has both the red and green light solid after the 4 digit code has been put in and the engine fails to start. The key pad has the C and S on it, I have read you can remove the pad once the engine is running but I need to know if the pad can be disabled without the engine running?!?!?
Please help!
Hi mate, if im not mistaken, this thread will help you out (temporarily)
http://www.lancerregister.com/showthread.php?t=289053
Scroll down a bit on that page for piccies.
Thank young man, your a legend!
No problem, glad to help.
Big Grin
(27-02-2011, 11:41 AM)Andre Wrote:  Hi mate, if im not mistaken, this thread will help you out (temporarily)
For any future reference of any one with this same problem, if you follow as the guys says on the link above, but DO NOT remove the plunger! Just cut the two wires then hard wire from the solenoid end 1: to the ignition live and 2: to earth.
This is what I did and it cut the immobilizer out and it started the engine fine every time, there isn't allot of room to play or allot wire so cut the wires as near the middle as possible to say yourself allot of anger and shouting!
A big thanks to those who pointed me in the right direction in the first place on the site, I shall be back! Big Grin
[-] The following 1 user says Thank You to garywilliams2010 for this post:
  • Andre
Last Post: magoo1
Yesterday 06:31 PM
» Replies: 74
Last Post: Dyane6
Yesterday 05:19 PM
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
