  • 9 Vote(s) - 3 Average
Retrofitting air con
Hi,
Is is possible to retro fit air con to a Berlingo vtr 1.6hdi and has any one done it and how much.
If no, Any body got any ideas where i could get it done.
(23-08-2012, 04:16 PM)Muppet1 Wrote:  Hi,
Anything is possible, BUT I bet it would cost a fortune!!
Google is your friend.
There are plenty of companies who will be only too please to take your money and do this work for you. Probably cheaper, quicker and easier to buy one with it fitted from new.
My van had AC from new, but for some odd reason all the parts of the system are no longer there???
All the electrical is still installed so its a little odd
Hi Muppet1,
I know this isn't a lot of help, but I once retrofitted an entire aircon system to a Suzuki Grand Vitara. And...? I wouldn't do it again!
It was 5 years ago. I bought all the parts new at about £600. Then spent 3 days fitting them, changing the engine pulley and adding all sorts of wiring extras, new radiator and finally the dashboard switch. I then had to drive with it switched off, to an aircon specialist to have it leak-tested and filled for £75. It all worked fine. :woop:
Now, all that misery was without having to reprogram the flamin' computer to tell it about the aircon or impaling myself on the Citroen "DIY traps" located throughout the vehicle. :S
All in all, as Monty Python would say "Run away!!!".....
Good judgement comes from experience, and experience comes from bad judgement…
2017 Berlingo Multispace Flair 120
2013 C5 Tourer 2.2HDi Excl
Previously:
2012 C5 Tourer 1.6HDi auto
2012 Berlingo Enterprise 1.6HDi Van
2009 C5 Tourer 2.0D
2001 C5 Tourer 2.0D
2001 Range Rover 4.6 Vogue (really!)
[-] The following 1 user says Thank You to Argos69 for this post:
  • Muppet1
(27-08-2012, 10:29 AM)Argos69 Wrote:  I know this isn't a lot of help, but I once retrofitted an entire aircon system to a Suzuki Grand Vitara. And...? I wouldn't do it again!
Didn't even know Argos sold them.....:whistle::whistle::whistle:
Heh! I used Argos69 as my username cos it represented 2 of my favourite things in life - shopping at Argos and ...... Wink :eek: :whistle:
Previously:
2009 C5 Tourer 2.0D
2001 C5 Tourer 2.0D
I would never consider fitting it and I'm an air con engineer. It's not just all the gubbins under the bonnet, all the dash will have to come out to fit the evaporator. Swap the car, it's a no brainer.
I looked into this when buying my berlingo. Initially I thought that if you can buy a berlingo with ac, then the parts should retrofit into a non ac berlingo, this appears not to be the case, and the best I could get offered was a underseat unit which would cost about £1800 plus vat.
In the end I decided to spend another £750 on the XTR model with ac
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
