Thanks Given: 1
Hi, I have a mk 3 1.6 berlingo. diesel, 58 plate and I'm currently abroad with a blower fan (for warm / cold air inside the car) that has stopped working on all 4 speeds. A local garage has tested the switch, fuse, relay and resistors and can't find the problem. Any ideas would be welcome.
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
could it be the actual blower/fan unit
Threads: 5
Thanks Received: 8 in 7 posts
Well if the professionals don't know after an examination, I don't think your going to have much luck asking us lot, lol
good luck anyway, put the windows down until you get home.
Threads: 32
Thanks Given: 13
It's the resistor pack within the blower. It is a common problem.
Mine was exactly the same and I replaced it yesterday. It's the second time mine has gone faulty. I paid 20 quid off ebay for a new one. Expect 100 plus from the dealer.
As a short term solution to turn off the blower, disconnect the grey plug to it by removing the bit of carpet below the glove box where the blower sits.
