28-02-2011, 10:41 AM
The aerial was broken off (at the base) of my '05 Berlingo, I was told they are similar/same design to a Kangoo and the owner told me
“Basically I took parcel shelf out by removing the relevant screws, unclipped the roof liner (held in by plastic push-fit style poppers), you can then unbolt the wire going towards the radio unit and unclamp the base, the antenna topside came loose once the base was undone!
Not a difficult job and maybe only took 20/30 mins. to remove and refit.
2005 Multispace 1.9D poseidon blue
