  • 6 Vote(s) - 2 Average
Speaker and clock light problems
Hi guys
I am fitting new speakers to the front doors of my 2006 berlingo and haven't got the right connectors so want to just through crimp the cables on and snip the connectors off but I'm not sure on the polarity as the cables aren't well marked.
I also have an issue with the clock on the centre console as it is working but the rear illumination has gone out....is this easily fixed too ?
Any help welcome and thanks for looking
Have a search on here for your problems there is two threads showing you how to change the bulbs in the display (dead easy) and also on speaker change with all the info you need.
  • peacey
clock lights simple.just tug the surrounding plastic sort of towards you and up.undo the 2 screws and change bulbs.you cant go wrong.Big Grin
(25-08-2012, 02:40 PM)Tomcat3 Wrote:  Have a search on here for your problems there is two threads showing you how to change the bulbs in the display (dead easy) and also on speaker change with all the info you need.
I've checked the forum for speakers and they just said make sure they match and take pink as + but not important :-) thanks for the help I'll give it a try
(25-08-2012, 02:41 PM)lorraine Wrote:  clock lights simple.just tug the surrounding plastic sort of towards you and up.undo the 2 screws and change bulbs.you cant go wrong.Big Grin
I'll go and give that a try :-)
Awesome......speakers fitted and working and faulty bulb located too :-)
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
