Threads: 3
when i switch my engine off there is like a whistling noise in engine bay near fuel filter area .it lasts about 10 seconds. also van starts to run rough sometimes seems to lose some power,if i stop and switch van off then start it again its fine .might not happen again for months .:brickwall: 02 1.9 diesel van dw8
Threads: 82
Thanks Received: 397 in 340 posts
Thanks Given: 173
21
Fuel pump pressure (+/-) subsiding could be the whistle.
Fuel filter clogged maybe for the second one.
Wouldn't hurt to change it if it hasnt been done for a while
Threads: 3
just feplaced rocker cover gaskets and put everything back together and engine noise has stopped for now:woop:
Threads: 82
Thanks Given: 173
21
(28-08-2012, 06:22 PM)bluelingo Wrote: noise is back again any ideas?
All the citroens(all diesels) I have owned quietly whistle for a few minutes as you describe,including the C15 which was a 1.9 non-turbo.
All of them did this from new.
As long as the motor otherwise runs ok I wouldnt worry
