Brake Pads/Disk suppliers?
Thanks Received: 18 in 14 posts
Thanks Given: 30
Hi all!........ How the devil are we?....... I need to order some front brake pads and disks for my 1.9D 2003 (No ABS)..... Need to keep costs down as much as possible, but at the same time I don't want to get a crappy set that'll need replacing again soon! :brickwall:
I Just wondered if anybody could recommend a parts supplier that I could order from online that aint gonna leave my pocket empty?
Thank you, :thumbsup:
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
The following 1 user says Thank You to j90xxx for this post:1 user says Thank You to j90xxx for this post
• LloydyBoy
Threads: 67
Thanks Given: 237
50
Plenty on Ebay ... Mintex for £45 delivered and other makes for less than that. Brembo from around £55 delivered.
Serieal Berlingo owner
• LloydyBoy
Threads: 147
Thanks Given: 263
11
29-08-2012, 01:08 PM
(This post was last modified: 29-08-2012, 01:09 PM by Andre.)
Eurocarparts are your best bet. You might be able to save a couple of quid on eBay but you can have them in your hand today and at decent quality (Pagid/Eicher).
Edit: Just saw the online part in your OP. They do free delivery to, and time dependent it can be same day IIRC.
The following 1 user says Thank You to Andre for this post:1 user says Thank You to Andre for this post
• LloydyBoy
Threads: 67
Thanks Given: 237
50
The cheapest on Eurocarparts is £47.70 inc vat and postage - Eicher parts.
• LloydyBoy
Threads: 32
Thanks Given: 24
30% discount code - "midmonth30" - should help a bit.
The following 2 users say Thank You to Coco for this post:2 users say Thank You to Coco for this post
• Andre, LloydyBoy
Threads: 147
Thanks Given: 263
11
29-08-2012, 01:45 PM
(This post was last modified: 29-08-2012, 01:45 PM by Andre.)
(29-08-2012, 01:40 PM)Coco Wrote: 30% discount code - "midmonth30" - should help a bit.
Typical, i used a similar code a month or so ago to purchase pads and discs. Only a week or so ago said code had expired and my exhaust rusted out & couldnt wait...
Thanks anyway  illyme:.
Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
(29-08-2012, 01:08 PM)Andre Wrote: Eurocarparts are your best bet. You might be able to save a couple of quid on eBay but you can have them in your hand today and at decent quality (Pagid/Eicher).
The words decent quality and Eicher should never be used in the same sentence. Fitted some on mine an were warped after 15k miles
Pagid, Mintex, Brembo, Ferrodo are you best bets
The following 2 users say Thank You to 800HDI for this post:2 users say Thank You to 800HDI for this post
• LloydyBoy, ron
Thanks Given: 30
Thanks for the posts fellas. All these prices are a lot cheaper than I had been quoted.....
Phoned a few auto part places in my home town and was quoted £80 + VAT, £60 + VAT, thought I'd phone up Hellfrauds as well, (just for a laugh of course), £90 for the set............. There's some cheeky B******s about...........
One last question if you please?........ My van is a 2003, 1.9D with NO ABS. A couple of the places asked if they were vented or non vented discs.... Will both of these options work for me, bearing in mind the Berl has no ABS?....... Was also asked to check the calipers to see if they were Bosch or another make, don't understand what difference this makes........ Must admit I do want to get the right ones though.
Thanks guys :-)
Threads: 147
Thanks Given: 263
11
29-08-2012, 04:47 PM
(This post was last modified: 29-08-2012, 04:49 PM by Andre.)
(29-08-2012, 04:38 PM)LloydyBoy Wrote: Thanks for the posts fellas. All these prices are a lot cheaper than I had been quoted.....
Thanks guys :-)
To be sure just give them a quick check yourself, turn the steering wheel left or right so you can grab the disk, and have a feel. The vented discs will be thicker, like two discs together with a small gap between:
[Image: VENTED_DISC.jpeg]
(29-08-2012, 01:48 PM)800HDI Wrote: (29-08-2012, 01:08 PM)Andre Wrote: Eurocarparts are your best bet. You might be able to save a couple of quid on eBay but you can have them in your hand today and at decent quality (Pagid/Eicher).
I was talking generally having used both brands interchangably from ECP without any trouble (yet), getting good miles out of both.
For another company, try http://www.carparts4less.co.uk/ - a sister company of ECP that sometimes has the same parts at lower prices.
• LloydyBoy
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
