Threads: 2
Thanks Received: 4 in 3 posts
2002 Mk1 2.0 hdi multispace desire have a problem 1st the interior lights will only switch off at the lights & not when the doors close, if the lights are on & you start the engine the lights will only dimmer & not extinguish, then a day later the side lights come on when braking & somtimes will blow a 5amp fuse for one side of the light circuit. I have removed the rear light clusters & disconnected them & also disconnected the towbar electrics & the problem is still there as you see the front lights will come on when the brake pedal is pressed. I'm not sure if the BSI is the problem or not. Can anybody please give me some information to cure this problem.:brickwall:
Threads: 10
Thanks Received: 16 in 12 posts
Thanks Given: 10
(29-08-2012, 08:53 PM)beagle65 Wrote: 2002 Mk1 2.0 hdi multispace desire have a problem 1st the interior lights will only switch off at the lights & not when the doors close, if the lights are on & you start the engine the lights will only dimmer & not extinguish, then a day later the side lights come on when braking & somtimes will blow a 5amp fuse for one side of the light circuit. I have removed the rear light clusters & disconnected them & also disconnected the towbar electrics & the problem is still there as you see the front lights will come on when the brake pedal is pressed. I'm not sure if the BSI is the problem or not. Can anybody please give me some information to cure this problem.:brickwall:
Don't know much about lights, but when I get mysterious behaviour from the electrics, first thing I check is all the earth connections.
Married to BandanaLady.co.uk
Threads: 32
Thanks Given: 24
As above. Check, clean and refasten all earth points first, then let us know how you get on
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
Try disconnecting the brake light switch mounted on the brake pedal.
Threads: 2
30-08-2012, 05:08 PM
(This post was last modified: 30-08-2012, 09:19 PM by beagle65.)
stripped the connection under rear floor pans found them very corroded, gave them a clean & now problem is intermitant & interior light is also working now correctly
Threads: 23
Thanks Received: 24 in 15 posts
Thanks Given: 11
Can you give us the precise location of these points as I am sure it will be a great help to others here.
