  • 10 Vote(s) - 3.1 Average
2.0HDi Fuel Filter Housing Draining & Cleaning
I'm about to do my own service on the Berlingo for the first time. I've been reading the Haynes joke book but, as usual, it's pretty useless.
Can anyone tell me how to drain the fuel filter? Also, what do you use to clean out the fuel filter housing prior to fitting a new fuel filter?
:thumbsup:
There is a drain tap at the bottom with a length of clear hose attached.
I just use clean lint free rag to wipe out. It shouldn't need cleaning really. The securing ring on top can be tight, either use a special tool, Andy Womble posted a link to one that he bought from Ebay, or I use a piece of wood to gently tap it round. Take your time and it will come free just don't be tempted to give it a whack !
The new filter should come with bungs to fit all the fuel pipes whilst you have them off.
Good luck
I use one of these
http://www.toolstop.co.uk/index.php?opti...edium=base
I did mine by hand, It wouldnt move in the engine bay using a strap wrench (Haynes quote "these are tight and we have not removed one without damage occuring") so I removed the filter housing and lightly gripped it in my vice, not tight and ensured that the mounting lugs were diagonaly braced against the jaws wrapped a rag round it and it unscrewed by hand!. I wonder if a strap wrench or similar in situ distorts the top ring causing breakage? anyway I now have a spare filter housing as I went to the scrappy beforehand just in case>
Last Post: TGD
Today 09:50 PM
Today 12:29 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
