  • 12 Vote(s) - 2.58 Average
fan switch
hiya lads , is it easy to change the blower stitch ,it only works on no;4,cheers, steve
ill have to get a haynes
03 1.9DLX van
Hi mate, this should be a simple fix. You sure its the dial thats fudged?
hiya mate, 123 on both sides dont work bur 4 does
gonna have a proper look the weekend
03 1.9DLX van
Ill see what Haynes says when i get home. Should have some removal instructions.
Unless of course, pk gets here first!
Yes. Of course I have. Wait please.....
Removing - refitting : Cooling cassette
1. Preliminary operations
Remove the following components (see the corresponding procedures) :
Front bumper and front bumper crossmember
Headlamp
Front panel
Drain the air conditioning system (see corresponding procedure).
2. Removing
[Image: 001dp.png]
Unclip the anti-recycling partition 1 (at "a") (on each side).
[Image: 002.png]
Remove :
The bolts (3)
The cooling fan
Disconnect the connectors , as "b".
Remove :
Remove bolts (4)
The air conditioning pipes 5
The bolts (2)
CAUTION : Immediately close the air conditioning circuit using caps to prevent damage to the air conditioning circuit desiccator cartridge.
[Image: 003se.png]
Unclip the connector in "c".
[Image: 004zg.png]
Unlock the top brackets 6 by rotation (as per arrows).
[Image: 005wu.png]
Release the harness (7).
Remove :
The bolts (8)
The relay bracket (9)
The electrical harness (7)
Unclip the electrical harness at "d".
Detach the radiators from the lower brackets of the cooling cassette.
Remove the cooling cassette.
3. Refitting
Proceed in the reverse order to removal.
How to dismount front bumper described here:
http://www.berlingoforum.co.uk/showthread.php?tid=270
thanks very much lads
its the switch on the dash ,below the radioSmile
03 1.9DLX van
(01-03-2011, 05:41 PM)stevetiler Wrote:  thanks very much lads
Well you're having this one replaced as well now we've got it all stipped downExclamationExclamationExclamationBig GrinBig GrinBig GrinBig GrinBig Grin
(Do I sound like a main dealer or what)
sounds fair andyBig Grin
03 1.9DLX van
steveteler.
It was very useful to explain for silly foreighner(to me) what did you mean.
In fact there are two blowers in Berlingo.
And what did you mean - it's very difficult to understand....
(01-03-2011, 07:44 PM)stevetiler Wrote:  sounds fair andyBig Grin
Your bill's in the post guv'nrRolleyesRolleyesRolleyes
Last Post: BigVtwin996
Today 12:10 PM
Eolys replacement tank
Last Post: jw4821
Today 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
