  • 9 Vote(s) - 2.67 Average
Citroen Berlingo towbar wirring
I was wondering if anyone can help, i purchased a tow bar with electric cable (long black with different colors), my question is where can i find the wires to mix and match the ones on the tow bar.
what part of the car are they located,03 Berlingo
Mine is wired into the rear light cluster. Remove the panel on the offside rear - the one that covers the jack. Easy to get to them from here.
Worth doing a search and reading up on others experiences with the wiring before you start
(01-09-2012, 01:28 PM)Coco Wrote:  Mine is wired into the rear light cluster. Remove the panel on the offside rear - the one that covers the jack. Easy to get to them from here.
Thank you for replying
so in this location i am going to find the cables to connect the electric components for the tow bar
thanks
thanks
All the wires you need are there except the offside indicator (and also the offside tail-lamp if your wiring plan is going to be more than a basic install)
You will need to get at the back of the offside light unit for this and feed it up and over inside the rear door frame to the wiring on the other side that Coco talks about
Theres loads of experience here so take it a step at a time.
What are you going to tow?
If its just a little trailer then you can 'scotchlok' your new cable straight to the citroen wires.
If its a caravan then you will need a bit more involvement but dont worry for now.
Today 10:15 AM
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
24-10-2026 08:09 PM
