Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
Auxilary belt mate. Even asking for a fan belt at most motor factor would get you the correct part.
The following 2 users say Thank You to 800HDI for this post:2 users say Thank You to 800HDI for this post
• LloydyBoy, ron
Threads: 67
Thanks Given: 237
50
If I remember correctly the belt varies according to whether there is air conditioning or not, the registration number given to the supplier will sort you out. Make sure the pulleys are clean before fitting and check the rollers run freely.
Serieal Berlingo owner
• LloydyBoy
Thanks Received: 18 in 14 posts
Thanks Given: 30
Cheers Geoff......... Ordered off ECP online........ Put REG in so hopefully will get the right one....
Threads: 20
Thanks Given: 2,126
18
It could also be called a serpentine belt,ain't life a bitch?
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• LloydyBoy
Thanks Given: 30
Ron...............Life's a bitch and then you marry one.
Thanks Given: 30
She's a mail-order, Thai bride, Rustscrat so she can't read English anyway!!!!!!!......... (Yeah right, if only!)
Thanks Given: 30
After ordering the Drive Belt off ECP online, we come to fit it and it's the wrong bloody one. aaaaaaaaaarrrrrrrrrrrrgggggggggghhhhhhhh. It seems to be about an inch too small! When I put my REG in on their website, this was one of the belts it suggested for me, so not quite sure what's happened!
