Threads: 3
Thanks Given: 1
Hi All,
I've recently bought a Multispace 1.6 Hdi and am delighted with the features and usefulness of the car.
The only problem I've encountered is a smell of oil burning - it isn't exhaust fumes - particulalrly from the rere of the car. These fumes are noticable in the interior too, but not as strong. There is no evidence of an oil leak nor of oil being burned in the engine.
Anyone got any ideas?
Ta
Threads: 42
Thanks Received: 409 in 366 posts
Thanks Given: 137
31
exhaust fumes being drawn inside via back door seals
Threads: 13
Thanks Received: 30 in 30 posts
Thanks Given: 6
Double-triple check it's not exhaust fumes, as that would be the most likely culprit. If you can get the car (rear at least) on axle stands and feel for any exhaust leaks with the engine running... don't burn your hand though!
Whilst you're down there check the heat shielding is all in place above the exhaust system, and see if there are any signs of fluids (eg brake fluid) leaking onto the hot exhaust and causing the fumes.
It can be tricky trying to pinpoint odd smells or rattles, often it seems like thay're from one area but they're actually in a different area.
Threads: 25
Thanks Received: 47 in 29 posts
Thanks Given: 23
05-09-2012, 08:01 PM
(This post was last modified: 05-09-2012, 08:01 PM by jimbo.)
Are you sure its not an oil leak or old oil on the exhaust pipe ,mine leaks and drips onto the exhaust and smells
Threads: 20
Thanks Given: 2,126
18
Check you haven't picked up a bit of plastic on the exhaust,or wrapped round a driveshaft.
Strawberry flavoured windows
Threads: 42
Thanks Given: 137
31
Could it be the heater matrix leaking anti freeze and anti freeze smells
not like oil or exhaust but similar. It doesnt take much
Threads: 3
Thanks Given: 1
I've heard that from somebody else too. Is there any quick way of checking? I assume the anti-freeze would be leaking into the cabin/footwells?
