  • 8 Vote(s) - 2.63 Average
[Engine] Cam Belt Change two questions
I am the proud owner of a 1.9d 2004 Berlingo.
1.The manual states the cam belt should be changed after 75000 miles or 10 years. I'm on 50000 and 8 years. Is it worth getting it done or can I leave it for a couple of years?
2. How much will it cost?
Thanks in advance
Yes
I would never go to the recommended limits with a cam belt. If it broke the consequences are catastrophic. It probably means that the alternator belt has not been changed either and there are many instances of that belt breaking and wrapping round the crankshaft pulley causing the cambelt to jump or break, not a massive job nor too expensive for your peace of mind
Peter
[-] The following 1 user says Thank You to Romahomepete for this post:
  • ron
Today 01:49 PM
Yesterday 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
