[Engine] 05 Berlingo , no start after crank shaft pully change
06-09-2012, 03:24 PM
(This post was last modified: 06-09-2012, 03:25 PM by jones 19.)
Hello all
i think this is my first need to post as usually i can find answers from other posts, this site is very handy, anyway
a friend of mine who drives a 2005 turbo berlingo, im not sure if its 2ltr or 1.9ltr but my launch x431 master works with it under the siemens option.
he changed the crank shaft pully and since then it wont start,
i read codes off it and this is what showed
-cylinder reference short circuit between two wires,open circuit or no signal,permanent fault (is this a cam shaft sensor?)
and
fuel pressure signal pressure coherance ,permanent fault
when i clear them they come back on after cranking the engine,again the engine wont start, it will fire with easy start, there is no real pressure at injectors only a mere dribble,
glow plugs dont work until the engine is turning
interior fan doesnt work
i hope i havent made anyones eyes bleed reading this
also my friend disconnected the battery at some stage during repair
i did try the bsi reset but only once
many thanks
Jones
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
Hi, check the camshaft timing, Check the cylinder ref sensor which is located on the cam shaft pulley. :thumbsup:
2006 2.0hdi 600 with bench seat.
(06-09-2012, 07:04 PM)Rustscrat Wrote: Hi, check the camshaft timing, Check the cylinder ref sensor which is located on the cam shaft pulley. :thumbsup:
Hey rustscrat, do you know what readings i should get on a resistance test on the three pins on the camshaft sensor, and what voltage i should get on the supply plug pins, and supply pins to the crank shaft sensor ? the crank shaft sensor itself read 400 ohms,
thanks
Threads: 18
Thanks Given: 211
(08-09-2012, 10:18 AM)jones 19 Wrote: (06-09-2012, 07:04 PM)Rustscrat Wrote: Hi, check the camshaft timing, Check the cylinder ref sensor which is located on the cam shaft pulley. :thumbsup:
thanks
Sorry I can't help you with that one. It will probably be some kind of semiconductor device so you will be best off trying a replacement one.  alut:
Threads: 67
Thanks Given: 237
50
The sensor will almost certainly be the inductive type and there is a smashing test on YouTube which explains exactly what you want to do.
http://www.youtube.com/watch?v=XsTvKgWZxP4
Serieal Berlingo owner
The following 2 users say Thank You to geoff for this post:2 users say Thank You to geoff for this post
• ron, Rustscrat
Threads: 18
Thanks Given: 211
(08-09-2012, 01:12 PM)geoff Wrote: The sensor will almost certainly be the inductive type and there is a smashing test on YouTube which explains exactly what you want to do.
Nice one geoff.:thumbsup:
Threads: 67
Thanks Given: 237
50
No problem, nice to put a bit back into the forum for a change.
Threads: 6
Thanks Received: 6 in 3 posts
Thanks Given: 9
hi did you get to the bottom of this i have exactly the same issue
Threads: 6
Thanks Given: 9
new cam pulley and she's firing first turn of the key for the first time in 2 months so thought i would report back if anyone has this trouble in the future, the cam pulley and crank MUST be changed over if fitting an engine with the different engine code
The following 1 user says Thank You to ge0rge for this post:1 user says Thank You to ge0rge for this post
• ron
Yesterday 07:51 AM
07-04-2026 04:17 PM
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
