  • 4 Vote(s) - 4.75 Average
Need a gear box with a longer 5th gear
I have an r-reg 1868cc Diesel Berlingo, it has been converted for wheel chair access but I just use it to transport my motocross bike. It pretty much only does fast A-road and motorway use and is never loaded up.
I find the gear box has very short ratio's and for normal motorway speeds it revving quite high. Does anyone know if there is another gearbox I can fit with longer ratio's more suited for cruising at motorway speeds and if so what make and model does it come from so I get one and fit it
Many thanks Edd
Careful not to go too high -the 1.9 will bog-down quickly,forcing you to drop to fourth a lot more,defeating the point of the excersise
R reg 1868, surely a Berlingo of this age would be an XUD at 1905cc
Peter
You could get your box rebuilt with final drive off a 2.2 hdi?
Fitting 15" wheels instead of 14" wheels is probably easier.
The 1.9 n/a is a low powered engine for the vehicle size despite its cubic capacity and the gearing is arranged specifically for a working vehicle and it drives accordingly.Learning to drive leisurely is a part of the solution, sorry.
Geoff.
Thanks for the advice I do appreciate it and I will check the log book for what cc I've got, I only thought it was 1868cc as that's what I was told by Jayar components when I fitted a new power steering pump. I've been used to a 2 litre FWD short wheel base transit, unfortunately a few months ago I was hit from behind and the van has been written off.
I was given the berlingo by my grandad who up graded and I have been really impressed with the little van, I've got about two thousand pounds budget from the insurance pay out, with a majority of my journeys on motorways and fast a-roads which model would you guys recommend?
Sorry to be so naive for the last 10 years I've only had short wheel base LDV Convoys and transits.
Thanks again Edd
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
