  • 6 Vote(s) - 3.33 Average
1.9d newbie
Hi all,what have i done,i have just bought a 2000 1.9d forte 5door with 138000 on the clock,seems in good condition,seems sluggish after a 306 hdi but to be expected,new clutch last year,i will change oil and filters next week,paid £675 is that a good deal?what sort of milage are these engines capable of if looked after and what sort of things should i check over
thanks allSmile
[-] The following 1 user says Thank You to the admiral for this post:
  • taxi
(06-09-2012, 08:12 PM)the admiral Wrote:  Hi all,what have i done,i have just bought a 2000 1.9d forte 5door with 138000 on the clock,seems in good condition,seems sluggish after a 306 hdi but to be expected,new clutch last year,i will change oil and filters next week,paid £675 is that a good deal?what sort of milage are these engines capable of if looked after and what sort of things should i check over
thanks allSmile
They are capable of interstellar miles if looked after.At that age I would check/change everything,brake fluid,coolant,all filters & transmission oil.
Check/change cambelt if history not certain(incl w/pump.
That way you know for certain what's been done.Valve clearances should be ok,but worth a check.
  • taxi
thanks allSmile
Thanks very much for that Ron i will be dropping the engine oil and changing filters tommorrow,i noticed it has a lucas fuel pump,are they as good as the Bosch one do you know?
Welcome to the forum mate!
Next gen Berlingo coming 2030
Last Post: shedpete
Today 08:36 AM
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
