  • 12 Vote(s) - 1.92 Average
TAILGATE TRIM RETAINING CLIPS
Have tried searching for a link to buying tailgate trim retaining clips for MK2, but each time I search I get a link is broken warning. I'm sure there was a post or 2 regarding this matter but I can't find them.
My trim is rattling big time & removal revealed missing & broken clips of two different types.
Confusedcratch:
03 2.0HDI Forte. I need more cash....
Is it these you are after? http://www.ebay.co.uk/itm/10x-Citroen-Pe...4165d6f680
[-] The following 1 user says Thank You to Andre for this post:
  • CitroAddict
Many thanks Andre, that might be them, will have to go back & look at vehicle to double check. I also found some through Amazon that look sligtly different (but similar!) and there appear to be a pair of different types that fix at the rear wiper motor housing.
Like most people I am loath to try main dealerships due to years of dissatisfaction.
Cheers! Confusedalut:
I had to get them for my MK3 they cost 25p at a Citroen dealer.
I DO MISS MY BERLINGO Heart
[-] The following 1 user says Thank You to philip for this post:
  • CitroAddict
Following up the trim clips above - the ones you linked to are different from mine Andre. However, I have located some through autoclips.co.uk
Less than £3.00 for a pack of ten; too good to be true? Maybe, they are out of stock, but perhaps the company may of use to others here in the future.
(08-09-2012, 02:38 PM)philip Wrote:  I had to get them for my MK3 they cost 25p at a Citroen dealer.
Thanks Philip, might just try that and shrug off years of cynicism. Main dealer only 2 miles away. Smile
got a pack for mine of ebay.cheap.
[-] The following 1 user says Thank You to landcrab for this post:
  • CitroAddict
I put my cynicism aside & went the the Citroen dealer, came back with 20 new clips for not much more than a fiver. They are a different shape from the ones on the vehicle but *work absolutely fine*. Have seen the same on Ebay/Amazon, hardly any price difference, BUT !> autoclips.co.uk - further visits to site revealed part out of stock & they said they would phone back. Never heard a thing from them, perhaps one to avoid.
*The Citroen clips*: As I have said these work fine but note this: when I put the first new clip in place it fell out as the fit is too loose; after a few expleteives the problem was solved by wrapping a short length of sellotape around the clip retaining lug to hold it in place. This could also be achieved by sticking a piece of bluetak in the lug. Once you have done this to all 14 clips the trim panel goes back on fairly easily.....
A few well placed screws would have been a better solution in the original design and easily breakable plastic cilps would not be necessary.
[-] The following 1 user says Thank You to CitroAddict for this post:
  • philip
Just reviving a very old thread. Can someone confirm whether these are the correct clips for the tailgate trim (m59 - 2004 multispace desire)?
https://www.ebay.co.uk/itm/371030910486
I've replaced all that I could reach/haven't fallen out (10), and it's holding better than it was before, but some of them are still popping out. Maybe I need to use some double sided tape as well?
The panel was loose when I got the van, and these clips were already in the trim, but perhaps they were wrong to start and the cause of the problem.
When my rear window was broken by an idiot with a ride-on mower chugging past the man from Autoglass had a bag of Mini (the later Mini, that is) trim clips that fitted a treat and stopped the rattle that I had put up with for a couple of years. They've been there for 4 years now and not a sound........and that's after the rear screen has been replaced yet again.....
(12-01-2021, 08:50 PM)oilyrag Wrote:  When my rear window was broken by an idiot with a ride-on mower chugging past the man from Autoglass had a bag of Mini (the later Mini, that is) trim clips that fitted a treat and stopped the rattle that I had put up with for a couple of years. They've been there for 4 years now and not a sound........and that's after the rear screen has been replaced yet again.....
Ah, so it sounds like the clips may just be a bit crap anyway. I might try to source some of these Mini clips! Thanks!
2004 Multispace Desire 1.6 petrol
Last Post: Desdinova
Yesterday 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
