BSI, ECU swap
Threads: 2
Hi guys, I would need your opinion on this. Is it possible to take bsi, ecu, fuse box, ignition and central locking from Berlingo van 1,9d 2004 and use it on my 1,9d 2003 Multispace? Or does it have to be exactly the same model?
Threads: 50
Thanks Given: 743
13-09-2012, 02:22 PM
(This post was last modified: 13-09-2012, 02:23 PM by Ol'Jeffers.)
Why do you need to do this? What is the problem with the 2003 car?
I think aside from the obvious, the running gear will be the same and the ages
of both are close enough for no major differences. Hell of a job though.
If Rustcrat comes by perhaps he can have a quick look at the circuits of both
and tell you of any important differences.
Threads: 2
Thanks for taking an interest Ol'Jeffers. Well its basically this. Ever since I bought the car management light was on while driving, which is nothing unusual, but when I stop and turn off ignition (key out) all ignitions lights comes on and stays on for some period of time, in this mode nothing works. Only way to get it out quickly from this mode is to press and hold brake pedal for few seconds or lock car manually, sometimes help to press hazards. To add to the problem red STOP light started to flash on dash recently + another few lights are permanently on. While this is happening I have no wipers and most of the time no indicators. What else? …..oh speedo and fuel gauge are out too. I know I could send my bsi unit to be virginised, but then it needs to be reprogrammed back to the car and I don’t know anyone who would do it for me. There for I was looking for other solution to solve this annoying problem.
Thanks Received: 18 in 14 posts
Thanks Given: 30
I had some very similar problems to this mate, and it turned out to be a damaged BSI unit........ I too considered replacing BSI, ECU, Ignition etc. But in the end I didn't have to! I'm not saying he will, but I sent my BSI unit up to Rustscrat and he repaired it for me, now it's as good as new............ Just an option, but Rustscrat is definitely your man!
Threads: 2
Thanks for the tip LloydyBoy. I do have a strong feeling that this is BSI. Did you have to reprogram your unit after repair or was it just the case of "plug and play"?
Thanks Given: 30
Hi mate....... If the damaged BSI can be repaired there should be no need to virginise it! When I got mine back it was a case of plugging it in and away you go!!!!! Didn't even have to do a BSI reset......... I thought mine was absolutely knackered to be honest! I had no speedo, revcounter, fuel gauge, temp gauge etc. and also a flashing cluster of lights on the dash for 9 months. All the functions on the van worked fine and it drove fine as well so don't lose the faith mate............ Rustscrat is the BSI Daddy!!!!!
Threads: 2
(14-09-2012, 07:07 AM)LloydyBoy Wrote: Hi mate....... If the damaged BSI can be repaired there should be no need to virginise it! When I got mine back it was a case of plugging it in and away you go!!!!! Didn't even have to do a BSI reset......... I thought mine was absolutely knackered to be honest! I had no speedo, revcounter, fuel gauge, temp gauge etc. and also a flashing cluster of lights on the dash for 9 months. All the functions on the van worked fine and it drove fine as well so don't lose the faith mate............ Rustscrat is the BSI Daddy!!!!!
Hi mate, I hope you right. I'm trying not to lose my faith, but sometimes it's hard. :S
Threads: 2
(14-09-2012, 08:11 PM)horinkova Wrote: (14-09-2012, 07:07 AM)LloydyBoy Wrote: Hi mate....... If the damaged BSI can be repaired there should be no need to virginise it! When I got mine back it was a case of plugging it in and away you go!!!!! Didn't even have to do a BSI reset......... I thought mine was absolutely knackered to be honest! I had no speedo, revcounter, fuel gauge, temp gauge etc. and also a flashing cluster of lights on the dash for 9 months. All the functions on the van worked fine and it drove fine as well so don't lose the faith mate............ Rustscrat is the BSI Daddy!!!!!
OK, I bought secondhand BSI,ECU unit, ignition barrel and the key. Was given VIN code of the vehicle and was told that it had around 80 000ml . I think you know where I am getting with this. Now I have 235 000ml on the clock instead of my original 122 000ml and I couldn’t get the thing started anyway. What an old fool I am. I didn’t have much time to play with it, just plugged new BSI and ECU in, then slit plastic receiver from original barrel and tape new key to it in attempt to trick immobiliser and used my original key to crank ignition. Engine was turning but wouldn’t start. Either I am missing something or new key is not coded to BSI.
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
(16-09-2012, 09:17 PM)horinkova Wrote: (14-09-2012, 08:11 PM)horinkova Wrote: (14-09-2012, 07:07 AM)LloydyBoy Wrote: Hi mate....... If the damaged BSI can be repaired there should be no need to virginise it! When I got mine back it was a case of plugging it in and away you go!!!!! Didn't even have to do a BSI reset......... I thought mine was absolutely knackered to be honest! I had no speedo, revcounter, fuel gauge, temp gauge etc. and also a flashing cluster of lights on the dash for 9 months. All the functions on the van worked fine and it drove fine as well so don't lose the faith mate............ Rustscrat is the BSI Daddy!!!!!
PM sent.
2006 2.0hdi 600 with bench seat.
Thanks Given: 30
I'm afraid to say mate that I think you may have wasted your money. Unfortunately It's not quite as easy as swapping the BSI, ECU, Ignition etc over and away you go. Honestly mate, the best thing to do is to get the original BSI repaired, trust me, I'm speaking from 'painful' experience.......... I see Rustscrat has PM'd you, so hopefully he'll put you right.............. Good Luck mate, chin up!
Last Post: Alberts elbow
Yesterday 10:11 PM
Yesterday 09:32 PM
Yesterday 05:46 PM
Yesterday 05:17 PM
Potential Purchase!
Yesterday 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 07:07 AM
