  • 7 Vote(s) - 4.14 Average
Front End Clunk
Just recently when reversing and then braking at low speeds I have started to get a clunk in the front suspension. Driving forward and doing the same doesnt produce the noise but reverse again and its there. My car is a 58 XTR with 40,000 plus miles. Does that sound like drop links and if so, should it be covered on my warranty or is that seen as wear and tear? If not wehat else could it be? Do the pads start to shift in the callipers and clunk?
Snap ! my 61 plate does exactly the same from 3,500 on the clock. Due its first service so was going to mention it at service time . I agree though, it sounds like pads moving in calipers.
My van has always done it. It's just the pads moving slightly.
Droplinks go clunk when driving over pumps etc. as i've just changed mine. They are easy to check, just look behind the wheel and check the bar the rubber and joint for any wear or damage at both ends.
Just had first service today and mechanic confirmed clunk experienced above is caused by pads moving in calipers. Oh well just another clunk to add to the rest of the rattles!
My van is making clunking sounds, the geezer who I brought it off mentioned the shocks. But then again neither of us have a scooby about mechanics
(05-10-2012, 11:39 AM)pitpan Wrote:  Droplinks go clunk when driving over pumps etc. as i've just changed mine. They are easy to check, just look behind the wheel and check the bar the rubber and joint for any wear or damage at both ends.
You need to stop leaving those training shoes lying around... SmileSmile
Hope they're not the petrol type
If it's a good "clonk" then I'd usually suspect the wishbone trailing bush.
Clunk click every trip ?
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
