Oil sump plug...
Threads: 30
Thanks Received: 6 in 6 posts
Thanks Given: 123
Hi all,
Hoping for a bit of advice for a complete novice (me)...
I have decided to do my own oil change on my 2003 2.0 Hdi Berlingo and am wanting to make sure I drain my oil sump and NOT the gearbox....:whistle:
Could someone please confirm which sump nut is the engine oil for me?  illyme:
Many thanks,
Kevin.
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
Hi, item 2 in the drawing. You will have a different sump if you have air con. But it's roundabout the same place. :thumbsup:
[Image: 29zod8m.jpg]
2006 2.0hdi 600 with bench seat.
Threads: 30
Thanks Given: 123
WOW, thanks for the detailed response Rustscrat
That is the one I released in the end, after much effort and various tools....It was on absolutely solid and unfortunately I ended up rounding the nut, but luckily it had a central allen key fitment that I used to loosen it.
Does anyone know if a Peugeot Partner sump nut would fit, only I want to get a new one and we don't have a Citroen main dealer where I live, but there is a Peugeot:thumbsup:
(16-09-2012, 04:17 PM)Rustscrat Wrote: Hi, item 2 in the drawing. You will have a different sump if you have air con. But it's roundabout the same place. :thumbsup:
Threads: 18
Thanks Given: 211
(16-09-2012, 05:31 PM)Merlecollins Wrote: WOW, thanks for the detailed response Rustscrat
Yep, they will be able to sort you out. Tell them it's from a DW10 engine(with or without air con) and they might have one on the shelf.
Part No. for Citroen & Peugeot W/O air con - 0311 29
Part No. for Citroen & Peugeot, Air con - 0311 40
 alut:
Threads: 30
Thanks Given: 123
16-09-2012, 06:36 PM
(This post was last modified: 16-09-2012, 06:37 PM by Merlecollins.)
Holy moly Rustscrat, you are a wealth of knowledge, I salute you  alut:
You've put my mind at rest for tonight anyway.
Are all 2.0 Hdi engines a 'DW10' ?
(16-09-2012, 06:28 PM)Rustscrat Wrote: (16-09-2012, 05:31 PM)Merlecollins Wrote: WOW, thanks for the detailed response Rustscrat
alut:
Threads: 30
Thanks Given: 123
OK, I now have my new sump plug which is manufactured by a company called 'Corteco'.:thumbsup:
In the packet there are two washers, one copper and the other steel with a rubber gasket.
Anyone know which washer I use?  cratch:
(16-09-2012, 06:36 PM)Merlecollins Wrote: Holy moly Rustscrat, you are a wealth of knowledge, I salute you alut:
alut:
Threads: 63
Thanks Given: 410
(17-09-2012, 10:08 AM)Merlecollins Wrote: OK, I now have my new sump plug which is manufactured by a company called 'Corteco'.:thumbsup:
Which type came off originally????, suggest you refit new plug using that type???
Threads: 30
Thanks Given: 123
I've done exactly as you suggest Andy and fitted a new copper one with the new plug. :thumbsup:
Still torturing myself about which oil to get....
When I was in the Peugeot dealership this morning they only had Total Quartz7000 10W40 in, but am swaying towards getting the Comma SynerD 5W40 for some reason......
(17-09-2012, 10:54 AM)andy-womble Wrote: (17-09-2012, 10:08 AM)Merlecollins Wrote: OK, I now have my new sump plug which is manufactured by a company called 'Corteco'.:thumbsup:
Threads: 63
Thanks Given: 410
Think I would be swayed towards the Total out of choice. I used it in my old Pug306 and have used it in my 'Lingo, though this time I used some Semi-Synth by Morris Lubricants as this came as a "package deal" from my local motor factor and included oil and filter plus air and fuel filters all for about £40.00, a massive saving on main dealer's prices and I did it myself so no labour content...
Rear seat belt breakage
Last Post: Mad one
Yesterday 06:09 PM
Yesterday 05:49 AM
11-09-2026 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
