  • 13 Vote(s) - 3.31 Average
dash oil level gauge
Hi on my 2001 berlingo 1.9D the oil level gauge that shows in the dash when first turning on the ignition is giving faulty readings one moment it might show 1 or 2 bars then the next time it shows full.
has anyone else had this happen to them or know what may be the cause.and would you be able to tell me where the sensor for this is located
thank you
Car not on level surface, or been started a short time prviously, as long as it is OK on the dip stick it is ok just ignore it
(20-09-2012, 07:19 PM)Husqyman Wrote:  Car not on level surface, or been started a short time prviously, as long as it is OK on the dip stick it is ok just ignore it
The lights may look pretty,but I always use the dipstick(level surface,engine cold)before & after a long trip.It's physical proof & all we had before electronics took over.
hi yes the level is ok by dip stick but llike haveing the gauge.its worked ok for the last 4 years so would like to sort the problem out if possible
cheers
There is a dipstick under the bonnet for checking the oil.
Pretty lights are for lazy people, and girls with soft hands and manicured nails.
And they often don't work.
Both of them....
[-] The following 2 users say Thank You to j90xxx for this post:
  • RolyG, ron
yes I know there is a dip stick and your right you dont need them theres a lot of stuff you dont need but its there and it was working ok now its not so would like to try and sort it ffs if your not wanting to help why bother replying
all I wanted was a bit of advice if anyone knew were the sensor is located
Just done a search and come up with this sensor http://www.ebay.co.uk/itm/PEUGEOT-PARTNE...5ae918de70
It may give you an idea on what you are looking for, perhaps the connection is a bit dodgy and needs a clean up.
let us know if you find it and sort it out.
(08-10-2012, 05:30 PM)hunter Wrote:  yes I know there is a dip stick and your right you dont need them theres a lot of stuff you dont need but its there and it was working ok now its not so would like to try and sort it ffs if your not wanting to help why bother replying
Same as you, mine worked fine for ages.
Now it gives a different reading every time you switch the ignition on.
If it suddenly started working again, would still check with dipstick, as I did before. May be a bad connection, or faulty sensor?
Is that a better reply for you?
Irony and a vague attempt at humour is lost on some people. Confusedillyme:
Hi, This any use??? Item 4120. Confusedalut:
[Image: llft2.png]
Last Post: rom4ik
Yesterday 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
