I have a berlingo van 2002 just had new engine fitted now I have another problem the temp gauge flicks Frm cold to hot and the stop light bleeps and flashes any ideas thanks
Threads: 0
Thanks Received: 19 in 13 posts
Thanks Given: 1
23-09-2012, 09:26 PM
(This post was last modified: 23-09-2012, 09:27 PM by tc_1.)
When that happened on my old 2.0 HDI it was it was the temperature sensor in the thermostat housing.
Were is that is it the green plug wid the 2 wires
above tried not solved the problem all wires checked coolant level sensor checked problem still persits had 4 differnt mechanics now and been plugged into machine still not fixed i just dont fancy given citreon £71 per hour any more sugestions welcom
there all puzzeld the stop light and temp gauge flash at same time its 1.9 d and yeah the fan does work when unplugged they just saying electrical fault of some sort as they tested everything and everything working fine
Threads: 5
Thanks Received: 3 in 3 posts
just thought i would say i had same problem stop light coming on and temp gauge shooting to top and down again it turned out it was the fan switch fault not paying £173.00 thats what citreon wanted as you have to buy the whole harness ect so i just put a manual switch in and keep an eye on it van i have got is 2003 hdi.
Threads: 3
Thanks Received: 1 in 1 posts
I've got same problem now, but mine's stuck on with temp at full and fan constant! Gonna check the fan switch out though if you say that's what the problem was on yours!
Threads: 15
Thanks Received: 4 in 3 posts
Thanks Given: 12
Hi there
see
http://www.berlingoforum.co.uk/showthread.php?tid=8044
I have the same problem. I asked to day at my local car shop, and they said change the cooler liquid sensor and all will be ok.
I will change it tomorrow as i pick it up then
My Car INFO:
CITROËN BERLINGO (MF) 1.4 i (MFKFX, MFKFW)
2005 Mod
Volum: 1360 KW: 55 HK: 75 Fuel: Gasoline
