Threads: 20
Thanks Received: 12 in 10 posts
Thanks Given: 1
Have just had to put my spare wheel on, on my 58 XTR and it was chucking it down. Problem is that it has a tow bar fitted and was a pig to get the securing strap unhitched from the carrier. When I replaced the spare in the carrier I found it very difficult to lift the rack into place and locate the securing strap. I found that putting the jack under the carrier and winding it up made so much difference. Also it is worth, if you have a spare minute or two, to undo the securing strap and grease the thread as mine had started to seize. You never know when you may have to fit your spare, wind, rain, snow!!!
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Or remove it altogether!
(If you have space in the back?)
Mine lives in the shed.
(The carrier; not the spare...)
Threads: 39
Thanks Given: 1
4
If your car is made with a spare wheel it should be serviceable, the breakdown services do not like to respond to punctures if a serviceable wheel is not present (when it should be)
Peter
Threads: 84
Thanks Received: 399 in 341 posts
Thanks Given: 179
22
I had a Bosal towbar on my MK2- it was a massive chunky lump of a thing but it didn't impede the spare.
Same story with the Witter Ive had on the last two Mk3's
What's going on under there BP ???
