  • 6 Vote(s) - 3.17 Average
starter motor?
ive just bought a 98 berlingo diesel van .from the beginging when you turn the key it would only turn over maybe a couple of times then catch and start,just. over the week this has got worse untill it just clicks without turning over.i bought a new battery thinking this might be duff but still no different ,so i presume its the starter/or relay can i check the relay if i remove the starter any advice before i start spending dosh please.as is apparent i am learning about van motors after restoring jap bikes the last 20 odd years,cheers mark.
Check all negative cables which go to body and power unit from battery.
Problem is not in a battery.
[-] The following 1 user says Thank You to pk7478 for this post:
  • whitebus
Indeed, sounds like a dirty earth problem. check and clean the ends of all earth cables, and maybe check conectivity of the cables. Another quick way of checking if this is the problem is to connect a jump lead between a metal part of the engine and the negative terminal on the battery. If this solves the problem - the earth cable is the problem.
Hope that helps.
Andy
[-] The following 2 users say Thank You to thowman for this post:
  • dirty berty, whitebus
Thanks Thowman and pk7478 - when I read your answers I had just returned from an "auto electrician" who told me that I needed a new starter motor. He also said he needed 2 hours to fit it - I decided to look up how long it should take and the consensus seemed to be under an hour. Then after further research I stumbled on this forum and found your replies to dirty berty. I tried running the jumper lead from the negative to the engine - guess what? It worked - thanks a lot guys - not only saved me a dollars but also saved me from yet another incompetent professional.
[-] The following 1 user says Thank You to ideolectic for this post:
  • whitebus
triangle light
Last Post: norm1
Yesterday 08:55 AM
Yesterday 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
